It is currently Thu Aug 21, 2025 5:01 pm
 Post subject: Router tables...
PostPosted: Tue Sep 24, 2013 2:19 pm
I've been thinking of adding a router table to the shop. Mostly I want it for bulk shaping braces. I coukd see how with a few easy fixtures one could get breaches radiused and tapered before glue up. Also thing like routing truss rod slots, shaping bridges etc.
Those of you who have one, how useful do you find it?
Thanks...
 Post subject: Re: Router tables...
PostPosted: Tue Sep 24, 2013 2:32 pm
State: ON
I find it very useful. I use it for shaping braces, occasionally cutting TR channels and a who variety of things not directly related to guitar making.
As a side note I upgraded a while ago to one of the Kreg bench top router tables. I find it to be a really nice table for the price. The open base gives quick and easy address to the adjustments on your router. If you go with an open table like this be sure to get a router with a twist depth adjustment. I happen to have a Hitachi on mine.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Tue Sep 24, 2013 3:13 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
One of the most useful things around - especially if you do more than just guitar making.
Pablo Picasso
PostPosted: Tue Sep 24, 2013 3:24 pm
Here is how I came at it.
I only use mine for cutting the TR channel.
PostPosted: Tue Sep 24, 2013 3:27 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Radiusing braces, truss rod slots, shaping the top contour of bridge, template routing peg heads and finger board tapers.
Kevin Looker
Edit
Also mortising head blocks - I do mine "before".
I'm not a luthier.
PostPosted: Tue Sep 24, 2013 4:00 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I have my router in the side extension of my table saw. I use the rip fence with auxillary fences with dust collection ports to do lots of routering jobs.
Alex
PostPosted: Tue Sep 24, 2013 4:31 pm
Lee valley router table .. couldnt live without it, use it for tons of stuff.
PostPosted: Tue Sep 24, 2013 4:44 pm
First name: Alex
Last Name: Kleon
City: Whitby
Is that the steel topped one, Tony?
Alex
PostPosted: Tue Sep 24, 2013 5:55 pm
I've got a Bench Dog table. Its a good unit. I've had it 10 years. Put in a Woodpecker Quick-Lift. I use it all the time for the things already mentioned. Once you have one you find a lot of uses for it that you never thought of before.
PostPosted: Tue Sep 24, 2013 6:01 pm
Sold!
PostPosted: Tue Sep 24, 2013 8:23 pm
One good tip for template routing of headstocks, bridges, etc. which you probably already knew is to take it down with the RoboSander first which leaves about a 32nd proud of the template. Then you can finish on the table with less chance of a problem.
PostPosted: Tue Sep 24, 2013 8:54 pm
Good tip, thanks....
PostPosted: Tue Sep 24, 2013 10:24 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
You'll need to have a solid understanding of climb cutting, & how to do it safely to get the most from your router table & avoid personal injury.
It's a great tool but can also be very dangerous.
Kevin Looker
I'm not a luthier.
PostPosted: Tue Sep 24, 2013 10:35 pm
Indeed. I plan on good solid hold downs....
PostPosted: Wed Sep 25, 2013 8:40 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
It is worthwhile to have a router with a 1/2" collet allowing for more robust bits. Some 1/4" bits tend to deflect more than the 1/2" ones.
Doug
PostPosted: Wed Sep 25, 2013 9:41 am
Good tips all, thanks....
Users browsing this forum: Kbore and 10 guests
